1 - 13 of 13 Posts
Not sure but here in Texas the water is very hard. I have a house system that I can hook up too. I feel your pain as I have used the other and it turns out just as you said. I’ve found that washing it out of the sun and ensure the car has not been run so the hood is cool. Get a good silicone squeegee and wipe the water off as soon as possible and follow up with a soft cloth.
21 Challenger Redeye, 21 Trackhawk
For washing the car I do have a 20-inch filter with I believe a .5 micron filter inside.
SimPure 20 inch Whole House Water Filter Housing, 20" x 4.5" Sediment Carbon Cartridge Universal Housing, Pre-Filtration System for Well and City Water, 1" NPT Inlet Outlet Port, Pressure Release https://smile.amazon.com/dp/B086XFC665/ref=cm_sw_r_apan_glt_i_JZTR7BSK5F4KB87K9H78
This won't help with water spots but the water is a little cleaner.
I use the filter to wash then the CR spotless to give a quick rinse then I have a Master Blaster to blow off most of the water.
JUST INTRODUCED! Air Force Master Blaster Revolution with 30' Hose MB-3CDSWB-30 MB-3CD SWB-30 https://smile.amazon.com/dp/B00UVUT...t_i_5S6VNRHAW48M8J6ANZ6W?_encoding=UTF8&psc=1
0.5 micron filter does nothing to make water softer...
Mabey, just mabey you should take the 3 seconds to read my first post, I actually write no filter will help with water spots. Then my next post where you got the quote from, where I say again this won't help spots, and I go on to write I use a CR Spotless resin system to take care of the spots.
Sometimes it's better to let people think you're an idiot instead of writing something and proving it.
But thanks for playing.
I use this. It's the same as the CR unit, but sometimes cheaper. No pre filter before the APEC unit though.
APEC Water Systems APEC Spot Free Water Deionization Car Wash System CWS-300, White https://www.amazon.com/dp/B01LY0WXU4/ref=cm_sw_r_apan_glt_i_XB20MQT46K21Y9VMW607
And that was supposed to mean what exactly? That you are nice and witty? I don't think you succeeded in either... Get a life and have a nice day.
Actually it was supposed to mean you should read the whole thread or at least the whole post before you write something.
And I do have a nice life and I am having a great day thank you.
1 - 13 of 13 Posts
