Hey guys I wanted to reach out and see if anyone else has switched to a Gen 5 Whipple 3.0 on their hellcats or Gen 3 hemi and have had any issues? I have seen more than one failure from friends and acquaintances recently and when they talked to Whipple apparently they will not warranty a GEN 5 Unit that has signs of "over spinning" and that over spinning is 18,000 RPM or more. They said if I plan on running more than 18,000 rpm I should buy spare whipple superchargers and switch them out to be rebuilt periodically.
This unit was touted as being able to spin faster and longer then previous units and could be run 22,000-24,000 rpm plus with no issues. I am currently running around 18,200 with my setup and making the same boost as my stock un ported hellcat blower did at 21,462 RPM redline. I didn't want to push the stocker any further so I upgraded. I have built motor all supporting mods to support some serious boost and now I'm thinking I should have went another route.
Is anyone else running a Gen 5 and if so what's your pulley combo/rpm you are running? How many passes/miles do you have on your setup?
