1 - 6 of 6 Posts
I have question for you thats in the know...my hellcats putting out 17lbs. of boost I'm thinking about going to a 3bar map is that something I need to do or not?And if so do all (four) map's have to be changed?If they do I guess I'll have to figure out what in the tune that will to change also. Thanks
@rookerrobert 3Bar sensor would be needed if you make more than 18lbs of boost as 2bar(In reality its more like 2.25bar) wont show past it .. But a tuner can work around it but you wont see anything above 18lbs on your dash. Changing the sensor all 4 of them will need change in tuning for the new parameters .
Discussion Starter · #6 · (Edited)
no sir going to 17lbs. it was 15 but when I installed the incognito it went up 2lbs. this what I found....
Bar to Psi Conversion Table
(Bar Psi [psi] 0.1 bar1.4503773773 psi1 bar14.503773773 psi2 bar29.007547546 psi3 bar43.511321319 psi)
And I might be guessing but I'm only using common sense boost is boost so the 2bar is 29.00
1 - 6 of 6 Posts
