A paste:
P0EA7-LTR PUMP PERFORMANCE
Theory of Operation
To improve engine performance the Charge Air Cooler (CAC) system is used to cool the charge air. The Charge Air Cooler (CAC) reduces the charge air temperature increase caused by the supercharger. The CAC system consists of an electric CAC Pump, Charge Air Coolers, Coolant Reservoir, Charge Air Cooler Radiator, Charge Air Cooler Coolant Temperature Sensor and plumbing. The CAC system operates independent of the vehicle’s primary cooling system.
The CAC Pump is a smart device that contains a LIN Bus communication module and a coolant pump. To maintain a desired charge air temperature, the PCM sends a pump speed command over the LIN bus to the internal CAC pump module. The internal CAC pump module controls the pump speed/coolant flow rate using Pulse-width modulation (PWM). The CAC Pump assembly monitors for internal system circuit and performance failures. If a fault occurs the CAC Pump module sends the fault information to the PCM through the dedicated LIN Bus. The PCM processes the information received, then sets the correlating fault.
When Monitored: This diagnostic runs continuously when the following conditions are met:
Set Conditions:
Default Actions:
BLOCKAGE IN THE COOLANT FLOW
LOW COOLANT / NO COOLANT
EXCESSIVE AIR IS MIXED WITH THE COOLANT
CHARGE AIR COOLER COOLANT PUMP
Theory of Operation
- With the engine running.
- No active circuit faults for the Charge Air Cooler Pump Assembly.
- Charge Air Cooler Pump Assembly above a minimum calibrated threshold.
Set Conditions:
- The PCM receives a LIN bus message from the Charge Air Cooler Coolant Pump that the pump current is either much greater than, or less than expected at a particular rpm.
Default Actions:
- The MIL light will illuminate.
