1 - 14 of 14 Posts
Widebody Hellcat Redeye
Hi has anyone else experienced the heated steering not working? Since I bought the car it has never worked, it lights on (in the display) and then goes off after around 2 seconds?
2016 Bright White Challenger
Are your hands cold? You have to have cold hands to qualify for heated steering wheel use
Sounds like a short. Should be an easy fix at the dealer. Is your warranty out or maybe you bought it used...
Discussion Starter · #5 ·
No dealer or warranty in the UK. All warranties from dodge are revoked if you export to the UK unfortunately , and yes I live in the north east of the UK so my hands are cold :)
Aw man that sucks. Well at least it‘s prob not a big dollar repair.
"I read the Owners manual, and it says:
HEATED STEERING WHEEL — IF EQUIPPED
The steering wheel contains a heating element that helps
warm your hands in cold weather. The heated steering
wheel has only one temperature setting. Once the heated
steering wheel has been turned on it can operate for up to
120 minutes before automatically shutting off. The heated
steering wheel can shut off early or may not turn on
when the steering wheel is already warm."
Its somehow sensing that its already warm I bet by the looks of it. I would check the settings to see if its set to come on automatically when you turn the car on (I had to turn mine off), maybe your car being newer has an extra setting that my 16 didnt have.
link to other problem reports; Heated Steering Wheel Duration 30-45 seconds? | Dodge Challenger Forum (challengertalk.com)
Dodge Bulletin attached
In The Market
Mine came on unexpectedly one morning when it dropped to 19F in the Eastern Sierra. Nice. Unexpected. Seems to know what to do on its own for me.
Have you tried checking if the left side gets hot, where the steering wheel should be?
Reactions: Baldnut
Discussion Starter · #14 ·
Many thanks for the info (y)
I have only tried mine when its been very cold and I have had the heating on full.I will try and play a little further but we are not talking 25-30 seconds more like 2 to 3 seconds before it goes off.
1 - 14 of 14 Posts
