also anyone that says that has NEVER driven a 6m hellcat.
Bro, why didn’t you change your own oil?So, the service tech comes out and says, "Man, why didn't you get this thing in a manual?
"It's a Redeye."
"What's a Redeye?"
Oh dear.
+1Bro, why didn’t you change your own oil?
With some of the dealerships horror oil change stories.
Is it over-filled?
There’s no way I’d let them touch my car. knock on wood
Because this car came with 10 years of free oil changes.Bro, why didn’t you change your own oil?
Is it over-filled?
nice. 10 years of damage and scratches being added to your car slowly but surely. Lol. I’m sure they don’t drain your oil cooler and if they do they probably break half of the retaining clips and throw your shit around like garbage.Because this car came with 10 years of free oil changes.
Poser! Just a clean room? Is it filled with inert Argon gas like mine is. Is your tux made of the finest, natural, analog, microfiber joyously donated by albino, blue-ringed octopi? Only the best virgin silk gloves here, buddy. Detailing??? Hell, I have the Fast and Furious cast steal the actual transport truck that carries the precious original assembly line drain plugs and filler caps destined for the Brampton assembly line.when I change my oil it’s done in a clean room while I wear a white tux and use velvet gloves…. I also detail the drain bolt, retaining panels, and oil cap.
jiffy lubeI couldnt imagine some 18 year old high school dropout changing the oil on my 100k car
‘Lol….nice. 10 years of damage and scratches being added to your car slowly but surely. Lol. I’m sure they don’t drain your oil cooler and if they do they probably break half of the retaining clips and throw your shit around like garbage.
Yeah, I always check the oil before I leave. Sometimes you get a tech who doesn't know what they're doing, but they generally do a pretty good job here. They drain the cooler, and typically refill it perfectly.‘Lol….
The most common thing dealerships do is over fill the engine oil. If it’s more than 1/2 quart, that’s not good for the engine. And they never drain the oil cooler on Hellcats.
Good luck with that issue dude. That kinda sucks on a brand new Hellcat.Yeah, I always check the oil before I leave. Sometimes you get a tech who doesn't know what they're doing, but they generally do a pretty good job here. They drain the cooler, and typically refill it perfectly.
On the plus side, when I got the car back the CEL was on. It's about a 15 mile drive to the dealership, so the car was nice and hot. It got started several times moving it around, checking for leaks and so on and it threw a CEL (sluggish start forced a misfire due to vapor lock or some similar cause). This is common with these cars, as most of us know. But, they took it over to the main service department and had them diagnose it. So, if it happens again, they have record of what's causing it and it might need an adjustment. I have been having random occurrences where the car dumps boost at around 4,000RPM on the dot (basically, the car breaks up a bit). It's extremely random and difficult to reproduce as it does it only 1-2x a month. The service manager thinks it's related. He knows I own a diagnostic scanner and he wants me to data log for a month or so until it breaks up again, then bring it back so they can see if the fuel trims or something needs to be looked at. So, at least the oil change might get the ball rolling on that issue.
I wasn't concerned about it, as I've had similar issues with my 2020 HC. This, however, seems like a minor configuration issue... not the COT thing, and can hopefully be remedied with an update.
Are you contractually obligated to use them?Because this car came with 10 years of free oil changes.
Damn! You don't have the best luck with cars do you? Maybe the tech at the dealership should be afraid to drive your car!Yeah, I always check the oil before I leave. Sometimes you get a tech who doesn't know what they're doing, but they generally do a pretty good job here. They drain the cooler, and typically refill it perfectly.
Nah, I could do it myself, but I don't have a problem with letting them change the oil. As I said, my goal with this car is to put 250,000 miles on it. It's not a garage queen. I don't treat it like it either. I take very good care of it, but this girl puts in work.Are you contractually obligated to use them?
Well, this issue isn't really an issue. Boosted cars do odd things, especially when heat soaked in Florida heat. I wasn't running the chiller or anything when any of those break-ups happened. The sluggish start thing is just about a common if not EVERY car happenstance for folks who drive in hot climates. They get vapor locked. For example, if I drive across town and stop to get gas, it'll slow start every time. My 2020 HC did the exact same thing.Damn! You don't have the best luck with cars do you? Maybe the tech at the dealership should be afraid to drive your car!
