1761 - 1780 of 1815 Posts
Challenger SRT Demon
Me again hey I’m now needing a quote for just the rear pair in 20x11 nano steel rims wrapped mounted & balanced tpms etc with Nitto NT555R in a 305/35/20 or a Nitto NT05R in a 315/35/20 this is going on my 2018 narrow body hellcat Challenger.
Area code 33914
Thanks!
If this is possible, I would like a quote for a pair of rear 20x11 Matte Vapor rims, TPMS, mounted & balanced, lug nuts if required, with Nitto NT555R in a 305/35/20 for a 2019 normal body Hellcat Challenger.
Area Code 34772
Need another quote on a set of matte vapor in 20x9.5 nitto nt555g2 in 275/40/20 & 20x11 with nitto nt555r in 305/35/20 with -21bS the works ready to bolt on.
Thanks
Vendor
Discussion Starter · #1,768 ·
So I’m trading my 17 for a Widebody.. I wonder how 20x11’s will look on it.
Its doable but for the widebody youll need to use adapters to get it to be flush
2019 Challenger Hellcat Redeye, Triple Nickel
Paul,
I have special ordered a regular body Redeye. I am thinking about running 11 inch HR5 wheels in the back, with 305/35/20's. I would like to run 10.5 HR5 wheels with the widest tire that will look good and not have any rubbing issues.
I have some questions I am hoping you can answer. A) Is my plan doable? B) If so, what size tire would you recommend on the front? C) What else do I need to do to receive a quote for the HR5 wheels.
Thanks in advance for any help you can give.
Jarrod
Vendor
Discussion Starter · #1,770 ·
Jarrod,
Hope your well, So this fitment will work for the front 20x10.5 a 5 mm spacer is needed to clear the inboard suspension and a 275/40/20 to a max 285/35/20 is what would be used.
PM has beent sent sir.
Paul A.
Can I get a quote for my 2019 Charger Hellcat.
I want (2) 20x11’s Matt vapor, TPMS with Nitto NT05R’s 315/35/20
Mounted balanced and shipped to 85260?
Thanks!
I've got a 2019 Scat Pack Charger that I'd love to get a set of these on. Are there any issues with 305s on the 10.5 inch rim? I'd likely go with Cooper Zeon RS3-G1's or similar. We get lots of rain here so a tire that handles well in the rain is important.
Ideally I'd like to have 305s all around as I'd like to be able to rotate my tires still.
275s are just not enough tire for near 500H. I couldn't even imagine them on a 707/717 HP Car.
If there isn't any issues what bolt pattern would I need for the front/rear?
Thanks!
