1 - 2 of 2 Posts
What code PO26E
P026E
Make:
Dodge
Code:
P026E
Definition:
Charge Air Cooler Coolant Pump Performance
Description:
To improve engine performance the Charge Air Cooler (CAC) system is used to reduce the temperature of the air entering the combustion chambers. The temperature increase of the air entering engine is caused by the Supercharger. The CAC system consists of an electric CAC Coolant Pump, Charge Air Coolers, Coolant Reservoir, Charge Air Cooler Radiator, Charge Air Cooler Coolant Temperature Sensor and plumbing. The CAC cooling system operates independent of the vehicle’s primary cooling system.
Cause:
FUSED B+ CIRCUIT OPEN/HIGH RESISTANCE
GROUND CIRCUIT OPEN/HIGH RESISTANCE
CHARGE AIR COOLER COOLANT PUMP
1 - 2 of 2 Posts
