Has anyone ever put a hellcat 2.4 supercharger on a demon/redeye?
The answer is most likely going to be no, as there's no benefit to it.Has anyone ever put a hellcat 2.4 supercharger on a demon/redeye?
I guess I’m gonna be the first lol it sucks i blew up my 2.7 and found a 2.4The answer is most likely going to be no, as there's no benefit to it.
The car is tuned by barth before it blewPorted snout, billet bearing plate, and a 2.85 or smaller pulley and you should get fairly close.
I know I know hahahaha
To many back to back highway runs I belive not paying attention to the tempshow did you blow it?
that whipple is going to add even more heat, fi interchiller is the way to go!To many back to back highway runs I belive not paying attention to the temps
Where you running a clutched pulley on it or a solid Metco type?To many back to back highway runs I belive not paying attention to the temps
I'm going to go the opposite way from some others here and tell you that you can make that setup work just as well as the 2.7L setup. In order for it to work similar, you would need a 2.85 upper pulley on the 2.4L blower to match a stock 2.7L. In the end, based on what has been tested by many, the 2.7L blower doesn't seem to go any further than the 2.4L blower when both have been ported. The 2.7L seems to be more sensitive to higher rpms than the 2.4L and reliability seems to go way down compared to the 2.4L. I've heard several theories for this. Ultimately, the Magnuson 2.65L would be ideal or the new Whipple Gen 5.Has anyone ever put a hellcat 2.4 supercharger on a demon/redeye?
Also throw on a 105mm or larger TB to let it breath, all of these mods will work together nicely.Ported snout, billet bearing plate, and a 2.85 or smaller pulley and you should get fairly close.
Or send it to Jokerz and have them port it and install upgraded bearings. That being said, its not necessary with a 2.85 pulley on a 2.4L blower, but its a nice upgrade for the future and will provide a nice power gain too.If you are going to overspin a stock blower......send it to Jon Bond first, then have it ported. Make sure it will not grenade.
Metco typeWhere you running a clutched pulley on it or a solid Metco type?
Well it was a grip Tec hahaThis is where everyone blames the metco pulley.......
