1 - 10 of 10 Posts
Vendor
OE front rotor (390x34mm) is a two piece while rear is still a traditional one piece rotor (350x28mm).
We all know the common advantage of a two piece rotor:
- Weight saving - For performance improvement.​
- Cost saving - When the rotor wears, you only need to replace the disc.​
Does your experience meet these two major criteria?
Vendor
Discussion Starter #5
Found some useful info on OE replacement:
Does anyone have a lead on replacement brake rotors for the 6-piston Brembos on the 2015 Charger/Challenger SRT 392's and Hellcats? I know decent aftermarket brake pads like Powerstop Z23's are reasonably priced, but what about front rotors? They look like they are going to be a lot more expensive than the $89 each I was spending on the front rotors for my 2007 Charger SRT8.
Answer:
Alright! I was afraid of this, but here are the part numbers and prices from Dodge:
Front brake rotors, part# 68184587AB $892 / EACH!!!!
Rear brake rotors, part# 5290538AC $113 each.
Front pads, part# 68248384AB $544 a set.
Rear pads, part# 68144223AA $115 a set.
That would be a total of $2,660 for front and rear brake parts! We need the aftermarket and we need it fast!
You might look at this replacement and shop Rockauto.com:
2019 Challenger SRT Hellcat Redeye Widebody
KNS sells a replacement USA made rotor ringsfor the front, made by Girodisc, that fits the OEM front hat.
Dba sells replacement front rotor rings.
Demon Performance sells replacement rotors with replaceable rings (made by Girodisc), proprietary hats and rings)
DP also sells teo piece replacement rear rotors, replaceable rings.
Vendor
Discussion Starter #9
Vendor
Demon performance rotors are great. We have had good luck with them on our personal cars and a lot of our customers purchase them from us as well ( a handful are on this forum), we have always had great feedback. DBA is a nice ring replacement options ( they are on back order at the moment though ).
- Alexis
1 - 10 of 10 Posts
