must be something with the revelco..I have a kill switch and If I forget I set it the push start is dead. maybe try the revelco forum if there is such a thing
Ya not sure. I called them, explained everything and they seemed pretty confident it wasn’t the revelco. I grabbed my other revelco plug and swapped it out. Same. Fuel pump runs tho which these things disable the fuel pump.must be something with the revelco..I have a kill switch and If I forget I set it the push start is dead. maybe try the revelco forum if there is such a thing
There could be two switches at the brake pedal. One to work the lights the other a starter safety interlock.I pretty much tried to check everything that was already mentioned right off the bat as I got a ride to my shop and grabbed some tools.
But to answer some of the comments. No the vehicle has never given me any issues in the past, been flawless as I take really good care of it. Revelco was installed the very first week of ownership over a year ago so it shouldn’t be a “bad install”
I always change my keyfob batteries every couple months due to how notorious they are of not lasting. I changed all the batteries including the vehicle battery anyways just to be safe.
Checked every fuse with my tester, A ok.
I didn’t go in too much depth with the Brake light switch (checking the ohms) because the brake lights work as they should upon depressing the brake pedal.
Tried doing the neutral trick and cycling the shifter into gear as I thought it might of glitched but that didn’t help. Even tho the starter didn’t give any symptoms either, I still smacked it and kept attempting to start it which didn’t help.
it’s under warranty, so im just gunna have it towed to my dodge up the street and see what they can find. It’s a bit hard tinkering in the driveway with limited tools. Especially if it’s something electrical.
I’ll report back when I find out what’s going on.
Wow that's a fun one.They just finished it. Something with a starter bolt ground on the heat shield. Here’s what was said on the paper work
1. VERIFIED CONCERN. UPON ARRIVAL FOUND NO VOLTAGE GOING TO STARTER RELAY PIN 30. FOUND THAT FUSE 07 OPEN. REPLACED 30 AMP FUSE. VEHICLE STARTED. TEST DROVE VEHICLE. UPON RECHECK VEHICLE WOULD NOT START BACK UP. FUSE 07 OPEN. TRACED CIRCUIT BACK TO STARTER. UPON INSPECTION OF STARTER FOUND NUT SECURING POSITIVE FEED TO STARTER WEDGED INBETWEEN SIGNAL CIRCUIT AND HEAT SHEILD CAUSING SIGNAL CURCUIT TO GROUND OUT. RESECURED NUT ON STARTER AND REPLACED 30 AMP FUSE AGAIN. TEST DROVE VEHICLE. VERIFIED REPAIR. - Ok to approve *00° Time 1.8
Paul S. 05/22/2023
RECALL
20A 2021-2023 WD Rear Spoiler
corduroy or zipper? Haha.Ha one of my 1.5T 23 year old Siemans gets bad RF artifacts from our light bulbs in the room..
