So I am the first owner of a 16 charger hellcat and it is running fine no issues since day one. The car is 68000 miles and never changed the transmission oil or checked it. Lately, I have noticed the transmission temps increasing when hard driving the car around 96-97 (usually it stays at 94 deg C since I have bought it with 0 miles on it).
Now I am planning to change the trans oil I got the filter and gasket.
Q1:
Anyone changed it at this high milage without issues?
Q2:
Do I have to drain the whole system or gust stick with changing the filter and topping oil to the fill plug?
*My car has no trans issue except temp at heavy load, temps are 94 °C and lower when crusing. No clunking no cracking noises 1st to 8th wether on Auto or shifting manually.
*one time it hit 99 and disengaged while doing a pull for a short period of time then came back normal , that was at 60000 miles, been fine ever since.
My local dealer in Saudi told me simply not to change it, but I guess we all agree on two things:
1.Dodge dealers are never trusted.
2.Any type of oil on the car requires changing.
Any help is highly appreciated
Thank you
Q1:
Q2:
Thank you
