I have a 21 charger hellcat widebody. I was thinking about trading up to a redeye widebody charger. The main question I have is......if I pulley and tune both cars on 93 pump gas. Will the ending hp numbers be pretty much the same. I did research and this is what I came up with.
The regular hellcat boost is about 11 psi from factory with the 2.4l blower. A pulley can make it a safe on pump gas 15 psi. This is max safe psi on 93 gas. Of course injectors etc. I have seenthis make up to 780 whp from hhp website.
I heard the redeye has a 2.7l blower already running at about 14 to 15 psi. There is not a lot of room to spin the blower faster on pump gas. Whatever you could do on the redeye that's safe for 93........would it beach different than a pullied and tuned regular hellcat.
I know the redeye has a demon top end yad yada yada.. I would upgrade the driveshaft on my regular hellcat....diff brace and if needed rear axels. The redeye may have stronger internals but the regular hellcat has not proved to need them with pulley and tune. Upgraded motor on redeye ? Yes ..... needed for extra power nit really? I even read that the 2.4 blower handles more speed better than the 2.7.
So the main question is after tuning and pulley on 93 gas for both the redeye and hellcat. Is there much if a difference in performance?
