1 - 7 of 7 Posts
2015 Dodge Challenger hellcat manual
what's up hellcat page I am new to this page trying to figure out what's wrong with my hellcat! I have a 2015 dodge challenger hellcat manual. I'm at 38k miles on it I recently had a problem with my clutch I just got that replaced not long ago everything seemed to be good as I was heading out of town car was losing voltage very fast pulled off and turned of on me never wanted to start agin. I had it towed back home I was thing it could be my alternator replaced that turned on but then I did to pulls then car started to lose voltage again I had already new battery checked all my fuses but now I'm stuck where to go now car won't start anymore again. I connected some of my buddies with hellcats some of them told me could be my starter or my clutch sensor I just need more help figuring what the issue could be what I would get in the dash would say Reduce of power then voltage starts to drop. I also got a code that was U11bc I can't figure out what's going on any help I would appreciate it.
'23 Redeye Jailbreak
U11bc is a faulty signal from the ABS module. Either that module is going bad, or there's something wrong with the CAN bus. Given your current power issues, sounds to me like you have a wiring issue somewhere.
· HOTM Winner
you need to separate out the possibilities -
you need to check for vampire power draws greater than what the shop manual would indicate for the car to see if something is drawing voltage that it shouldn't be.
You also need to verify the charging system is working.
You also need to verify the clutch pedal interlock is functioning.
1 - 7 of 7 Posts
