21 - 26 of 26 Posts
Discussion Starter #21
A little heat with map gas can be your friend.
I didn't try a heat gun I have because I thought if I heated that rod, expanding it would make it tighter. But if you think heat would help, I would try it.
X2 on the heat. 1500 watt heat gun should work but may need MAP torch.
You can always try a few 100 mph - 0 short stops to create some heat.. ?
Discussion Starter #24
going to try again this weekend. I will try a heat gun, and if that doesn't work, I'll remove the caliper and see if the pads can drop out of the bottom.
Thanks for all the suggestions!
The caliper body is aluminum and the pin is steel: the caliper will expand more than the pin. When I got my Scat Pack with the same brakes, the selling dealer had new brakes installed but didn't clean the pins on reassembly. I had to remove the calipers from the car and pound the pins out on a workbench using similar tools. I used the original bolts to get the pins moving, then replaced them with new ones on reassembly. I can't remember the size, but the local ACE Hardware had the right size and style.
Discussion Starter #26
thanks, I gave it another try tonight after work, and as SWETRID had said, when i removed the caliper the pads could slide out.
And luckily the other front did tap out, so i am about to put on the new rotor on the second front wheel and then i"ll close it up and bed in the brakes tmr.
I'm very happy!
I cant remember but can you take caliper off spindle and insert pads from bottom and then install pins?
21 - 26 of 26 Posts
