1 - 8 of 8 Posts
I have a 2016 Hellcat Challenger I was going to do a simple killswitch on the power source of the push to start I got it all hooked and ready tested it and now the push to start wont work at all.
All other lights light up and my dash lights up but the push to start is not getting any power it seems it wont light up at all.
Aside from all that the key fobs wont lock or unlock the car now either both the black and red FOBs wont do anything and they were working perfectly before.
So in my panic I went out and got a new push to start module thinking I fried it but that one as well is getting no power.
Do you think I fried the relay or possibly something else?
Put everything back the way it was and check fuses.
Also disconnect the battery for 30 minutes to see if something resets.
Hopefully you had the battery disconnected while doing the wiring changes.
If the fobs don't work after all of that, I'd say that maybe you triggered a security
system event and you may need a Dodge dealer to fix it.
I have several security mods on my car, but never messed with the Start switch.
I have challenger hellcat 2019 and it won’t start at all. I checked the fuse box and it’s F33 fuse blowing up. I replaced it several times with no luck and help will be greatly appreciate
Thank you
Challenger SRT Super Stock
I didn't read where you've put your wiring back to the way it was stock. Probably the best starting point. As mentioned, a blown fuse, in this situation, is a good thing. Without it you would have certainly caused greater damage.
1 - 8 of 8 Posts
