The kit come with full instructions in regards to wiring pumps. If you bought the lc3 controller it’s pretty straight forward, if not your going to have to wire up some relays. The vacuum line will need to be drilled on the top hat of the supercharger. The gas level sender is not polarity sensitive as indicated in the instructions and kit provides the necessary butt crimps for the install.
