1 - 7 of 7 Posts
Anyone install one? Was thinking about their kit or tapped performance. Let me know your thoughts.
Thanks,
I have a Tapped Perf kit, truly plug and play. Ricks customer service is top notch as well, I personally can say from experience you won’t be disappointed in his kits. Everything is there that’s needed Included very detailed installation instructions.
· Super Moderator
The kits are practically identical.
HHP developed the kit years ago with Fore innovations back when my husband @Top Cat and I were out T&T and R&D of parts and Tuning. "Top Cat" Challenger had the 1st one installed 😎
The kit has been repeatedly released under many different names over the years.
It's in stock at HHP, ready to ship and on sale.
HHP Racing Plug & Play Dual Pump (Walbro HELLCAT 525LPH) Returnless Hellcat Fuel System (2015+ 6.2L Dodge Challenger & Charger) - HHP.HC.FUEL
This is a great upgrade from the KB BAP
Happy Shopping
Linda
· Super Moderator
Sales would definitely know 18888941115
I think you will find and I'm pretty sure Josh had the HHP kit upgraded over the years.
If Fore is the main mfg I just cant see the kits not being comparable.
Linda :)
I have read quite a few posts that say HHP isn't true plug n play like tapped or others. I'm going to call Monday and speak with someone from HHP. I don't want to cut & splice wires.
Ricks kits are 100% plug and play, 0 splices. You can go back to stock any time and never know the system was ever touched. Rick even made me a adapter so I can use his pump feed lead plugs to adapt to his competitors pump setup, the Steve White dual 295’s in a stock pump basket so I can switch to any system with just plugs, Fore Based, Steve White based, or back to stock. And didn’t charge me an arm and a leg for it. I highly suggest calling him as well before settling on any system, I’ll PM you his cell #.
That HHP kit is so easy to install. Plug and play for 99% of it. The only thing you need to swap from the oem can is the fuel level float. This is a super easy install and one I wish I had done sooner.
1 - 7 of 7 Posts
