1 - 1 of 1 Posts
· Forum Discount Code: HELLCATORG
RAM TRX / Jeep 392
HOOSIER Drag Bracket Radial Tires are in-stock! Inventory noted.
The Drag Bracket Radial is a consistent, reliable and affordable product for the weekend sportsman racer. The new Drag Bracket Radial offers lower rolling resistance making it quicker than a bias ply in most applications. The radial design allows the tire to always have the same rollout eliminating the need to match circumferences while also eliminating the need to run tubes.
Order Here: https://dragracingwheels.com/drag-bracket-radial/
Below are some good alternatives to ET Street R or S/S tires in 305/45R17 or 315/50R17 which are all on nationwide backorder right now, 4+ weeks from time of ordered. :(
Available Sizes Noted below:
  • 26/8.5R15 - 18805DBR
  • 26/10R15 - 18810DBR
  • 28/9R15 - 18815DBR
  • 28/10.5R15 - 18820DBR
  • 28/10.5R17 - 18825DBR - Good alternative 305/45R17 (27.8/12R17) - Hoosier is not as wide though
  • 28/10.5R18 - 18830DBR - Good alternative for 305/45R18 (28.8/12R18) - Hoosier is not as wide / shorter though
  • 29.5/10.5R15 - 18835DBR
  • 29.5/10.5R17 - 18837DBR - Good alternative for 315/50R17 (29.4/12.4R17) - Hoosier is .9 inch less wide
  • 29.5/10.5R18 - 18840DBR - Good alternative for 305/45R18 (28.8/12R18) - Hoosier is 1.5 inch less wide but taller
  • 29.5/11.5R18 - 18845DBR - Good alternative for 305/45R18 (28.8/12R18) - Hoosier is .5 inch less wide but taller
  • 29.5/11.5R20 - 18850DBR
  • 31/11.5R15 - 18860DBR
If inventory is not noted, they will ship out within 7-10 days of being ordered! Order Here: https://dragracingwheels.com/drag-bracket-radial/
573341
1 - 1 of 1 Posts
