1 - 13 of 13 Posts
‘16 A8 Shaker
Doesn’t NHRA still have rules for this?
Not sure when it applies haven’t had anything this slow in a long time think it might be anything quicker than 10 flat needs open lugs with 100% thread engagement
Challenger SRT Hellcat 6MT
You need at least 14 mm of thread engagement (which is about 9.5 lug nut turns) to be safe. Anything thicker than 6 mm won't give you that. If you want a thicker spacer, you need longer studs. Or you can use a special kind of lug nuts (called ET-style: google it) that will give you extra ~6 mm of thread engagement; this way you can get away with up to ~11-12 mm spacers and stock studs.
Discussion Starter · #6 ·
Like these?
I get over 12 turns torqued,10 turns by hand with almost 3/4” worth of spacers. Should be good then.
· HOTY Winner
Reactions: Unholy707
· HOTY Winner
Don't forget your rotor hat thickness lol!
  • Haha
1 - 13 of 13 Posts
