1 - 1 of 1 Posts
Administrator
See full PDF here: https://www.hellcat.org/attachments/hellcat_front_facia_removal-pdf.522403/
2015 - LA - DODGE CHALLENGER - 6.2L V8 SUPERCHARGED
13 - Frame and Bumpers/Bumpers/FASCIA, Front/Removal
REMOVAL
1. Raise and support the vehicle.
2. Remove the engine belly pan (Refer to 13 - Frame and Bumpers/Under Body Protection/BELLY PAN/ Removal).
3. Remove the front fascia lower closeout panel.
4. Disconnect the fascia wire harness connector (2) located under the washer fluid bottle (1) on the right side of vehicle.
5. Remove the four plastic rivets from the front splash shields.
6. Pull back the splash shield (4) and remove the bolt (5).
7. Using a long suitable tool (3), remove the hidden nut that is at location indicated (2). 2
8. Lift out both front fascia upper closeout panels (1).
9. Remove the six push fasteners (1) at the top of the front fascia (2).
10. Remove the nut (3) at the top of fender (1) on both sides of vehicle. 3
11. Pull the sides of the front fascia (2) to disengage the retainers (3), then pull the front fascia forward and remove.
1 - 1 of 1 Posts
