1 - 12 of 12 Posts
My rubber intake tube (between the airbox and throttle body) has a white-ish powdery layer that's EXTREMELY hard to remove. I also found the (same?) stuff INSIDE the tube when I removed my air filter for cleaning. The throttle body itself looks clean.
I've tried: wiping it with a dry towel (this got some of it out), and brushing with water/dishsoap (didn't help much)
Anyone know how to get rid of this? Is it bloom, or could it be something else? Should I be worried? Can post pictures if needed.
It's not a "plasticizer", wrong term. Many plastics have a lubricant package in its formula to help with release from the mold. It can leach to the surface over time. Perfectly normal even if not visually desirable. Heat makes it speed up the process of coming to the surface. Radiator and heater hoses do it too, most rubber (TPE and TPV) molded parts that are a hose have it to some degree.
Nothing to be worried about unless you are OCD out the wazoo. I'd leave it alone, especially inside the air intake. Get a piece of something in the combustion chamber and between a valve and its valve seat and you could end up with a burned valve.
I took mine off, cleaned with Dawn, and wiped down with rubber protectant.
It's being described as rubber bloom, the same term used when tires turn brown or rust colored. I wonder if a good tire gel would work?
Any thing used on your tires can be used on it. I had the same issue, hit it with some tire shine and it looked good as new again..
1 - 12 of 12 Posts
