1 - 1 of 1 Posts
Administrator
test
Info. take from a forum post....
REMOVAL, Challenger
1. Disconnect and isolate the battery negative cable.
2. Using a trim stick or equivalent, remove and disconnect the window switch (3).
3. Lift the mat (1) and remove the screw (2).
4. Using a trim stick or equivalent, remove the cover (2) then the screw (1).
5. Remove the three screws (4) at the bottom of the door trim panel (3).
6. Using a suitable tool (1), push the center of the fastener (2) then remove.
7. Using a trim stick or equivalent, release the door trim panel starting at the lower edge and working around the perimeter to disengage the retainer clips. Position the door trim panel slightly away, do not remove.
8. Disconnect the wire harness connectors.
9. Remove the door latch release cable (2) from the interior door handle (3).
1 - 1 of 1 Posts
