Hey guys, this is for a 2015 challenger hellcat:
Doing it this way, you don’t have to remove the knuckle, just the 2 bolts for caliper and 4 bolts for hub. Took about 2 hours total. Don’t have to touch parking brake either
- Remove 2 18mm caliper bolts (use a specialty low profile 18mm socket
- Remove rotor (wack with hammer)
- get a 1/4” E12 socket from Amazon (3/8ths is way too big, won’t work)
- grind socket down a little bit.
- remove axle nut (32 mm or 1 1/4”)
- use a punch and sledge hammer to knock axle back for clearance
- take out 4 bolts from back of hub
