Oil in the exhaust/coming out the back of the exhaust is normal, it’s used as lubricant for the catalytic converters to reduce friction and increase heat when burning off excess fuel. The smoke means the greenhouse gases are being cleansed thoroughly, like how you get smoke from burning residue off your grill. I’d be concerned if there was no smoke/oil coming out of the exhaust. Make sure oil is topped off, and also pull the upstream o2 sensors and use a fluid transfer pump and pump in half a quart of 5-w30 to lubricate the cats. 0w-40 is just for the engine, the cats require a different weight ti maintain efficiency. Hope this helps.
and Yes, I’m 100% joking. Do not pump oil into your cats. Sounds like something really bad man, hope your car is ok.
