Can you see the IC coolant flowing in/out of the small plastic reservoir? I can hear the pump running but there is nothing but stagnant coolant in the overflow tank. I'm used to GM systems where you can see the coolant flowing into the top of the tank and exiting at the bottom - clearly flowing through the tank. Just want to be sure I don't have a blockage in the system.
