use security torx screws and it becomes a pain in the ass to defeat, unless you have the bitThe IGLA is the most interesting to me. In the limited time I’ve had to research, I like that it keeps the remote start function available unlike a Ravelco and seems to be able to lockdown the RF hub. If you do the lockdown at the dealer, that’s it, no new keys without $$$ for a new unit. The Compustar seems like it could be complementary to either the IGLA or Ravelco as it appears to be more of an alarm system than an immobilizer. I’m not impressed by the idea of a kill switch. Either it’s too easy to find or it’s going to be a PITA to access every time I want to start the car. And if the thieves do find it, there’s a lot less stopping them now than if an immobilizer is installed.
My current plan is to use the following layers:
1. Neutral pull cover
2. IGLA
3. AirTags
4. Maybe Compustar
Regarding the neutral pull cover, I assume these are relatively easy to defeat? It could just be taken off the same way it was put on.
When you refer to RF Lockdown are you talking with your keys in a faraday pouch or box?None of them, neutral cover, simple kill switch, rf lockdown, done. Unless you like spending money, then buy what you want…then again it’s your car, so again buy what you want
That’s what I was originally thinking, but even those are pretty damn common these days. I myself already have drivers for those in my garage. Might have to dig and see if I can find something a little less known and readily available.use security torx screws and it becomes a pain in the ass to defeat, unless you have the bit
Everyone that has a Tazor may want to check out the updated firmware coming out tomorrow. It will have a security update the is a sequence of buttons with the cruise control buttons on the steering wheel and if not done in time and proper sequence it looks the brakes and starts the light show with the horn honking. And remote start still works just fine. Just a heads up.
Couldn't a thief just un-plug the tazer and carry on with the steal?
I was thinking about adding some JB weld on the strap as well. I added JB Weld to a radiator clamp on the tailgate of my Ram 2500. They were stealing tailgates around here like crazy.use security torx screws and it becomes a pain in the ass to defeat, unless you have the bit
1) Neutral Strap (with torx heads and JB Weld) - Bad idea, you still might need to get that cover off for legitimate purposes.I was thinking about adding some JB weld on the strap as well. I added JB Weld to a radiator clamp on the tailgate of my Ram 2500. They were stealing tailgates around here like crazy.
I’m going with:
2) IGLA -stops the key cloning and relay hi-jack
3) Air Tags- multiple (good to track it down in the first 24 hours before it sends a notification to the thieves who most likely have an iPhone)
4) Faraday box for all keys at the house (the IGLA should prevent this)
5)Maybe the Mopar EVTS? Thoughts? Might be over kill, but can be defeated with a GPS jammer.
6) Last but not least, being armed while driving, keep your head on a swivel.
Just hide/bury the specialized torx removal driver somewhere in the trunk amongst/under other things.1) Neutral Strap (with torx heads and JB Weld) - Bad idea, you still might need to get that cover off for legitimate purposes.
1) If I have to cut it off, so be it1) Neutral Strap (with torx heads and JB Weld) - Bad idea, you still might need to get that cover off for legitimate purposes.
2) IGLA -stops the key cloning and relay hi-jack - Do you know how incredibly rare relay attacks are? See faraday box highlight
4) Faraday box for all keys at the house (the IGLA should prevent this) - I love the faraday pouch/box crowd. Total waste of money. Your odds of failing victim of signal theft real low, like more people are killed each year by vending machines falling on top of them then being a victim of signal theft. Pro tip, don't walk by any vending machines.
Airtags, what ever, I wouldn't use them, but have no real problem with people that do.
I don't know what the mopar EVTS is and I'm not going to look it up either...odds are I won't like it.
Being armed while driving, I have zero problems with this, my only advice is you should be ready should the need arise. There are a lot of cowboys in the world, not many gun fighters, but every cowboy thinks they are a gun fighter but not every gun fighter thinks they are a cowboy
