I've had some random electrical issues recently. Once at the track, my car totally died mid way through a pull. Pulled over, got out and reseated the relays and took off. I've had a couple of times where at the house, car would not start. Lights come on, but no crank. In trying to figure out what is going on, I could pull the relays in the fuse box on the PS side of the engine compartment and reseat them and it would start. I tried adding a touch of copper seize to all of the terminals on the relays and reseated them. No change.
With the car running, the only 2 relays that will "kill" the car are the ASD and Ignition relays. Looking the relays over closely, they appear fine. I went to O'Reilly and they had replacement relays. I bought 2 and replaced the ASD and Ignition Relays.
I found this post where another guy was having a similar problem. Has anyone else had issues with those relays?
I'm hoping the new relays fix the issue. I had a decent pull going on last night at the track, but my car still cut out I'd say 4 times in the pass for split seconds. If it is not the relays, what else could it be?
www.hellcat.org
2016 Charger Hellcat Electrical Problem Dealer Could Not...
My HC has 23K miles on it and has an extended warranty. In late September I had a few random no start problems but no CEL. I explained the issue to the local dealer and they would not touch the car without a CEL. Was in Myrtle Beach October 8-23 on golf trip and it would not start. Went and...
