First one I did to mine as well... Looks great
Yes...where can we Charger guys get these? I've seen them for Challengers, but not so much for the Chargers.Very nice who has those. And any tips on the install.
The door already has the needed wiring for the existing oem door light. Just disconnect the oem light and tap into the line for the puddle light. This way it turns on when you open the door only just like the oem light.Can you list the steps for installing without removing the door shroud. I'm curious how you installed the locking clip on light and how you accessed the wiring on the light that's already in the door
Thanks
How far from oem light did you mount as the door cubby looks it doesn't leave much roomThe door already has the needed wiring for the existing oem door light. Just disconnect the oem light and tap into the line for the puddle light. This way it turns on when you open the door only just like the oem light.
The bottom of the plastic interior door can be pulled away with just removing a couple screws on the bottom. Pull it back and the puddle light fits inside. Takes about 15 mins per door. Sorry I didn't take pics when I did it
I don't seem to have those 3 bolts on the bottom of door. Also the distance you used would cause me to drill through the shelf. If I drill close to the oem light, will there be enough clearance from the speaker
I have a 16 that was built on August 15 and there are screws on the door panel.The light location is dictated by where you want the image shining. Too close to the oem light will cause the light to shine on the sill instead of the ground. The hole is drilled only thru the plastic. You could easily plug it if you don't want it anymore. It faces down and you'll never see it unless you lay down and look under the door.
Your interior may be attached by clips. Mine are screws but I do have an early 15 model. The bottom of the interior pulls away enough to get the light inside and work on the wiring without removing the whole door interior.
Which type did you use. It looks really cleanHey Guys!
Fairly new to the forum. Thought I would show off my latest mod. One of my favorite mods so far!
View attachment 66665 View attachment 66673
