1 - 5 of 5 Posts
I have a 12" CAB in a ported box and CAB 1600.1 amp from my last car. I have delayed installing them as I wouldn't use it much, but there just taking up space in the garage and I'm not impressed with my HK system ('15 Challenger Hellcat). Is this a simple plug and play on this car? I read a couple threads where people talked about some electronics functions not working after stereo work. If I just tap into the Sub wire for the input can that mess anything up? Thanks in advance.
It's not truly "plug & play."
But hooking up the amp is easy...the power, ground, and remote wire are all in the trunk (the battery & the fuse box).
As for the signal...ideally, you'd want to tap into the speaker source BEFORE the factory amp so you're not amplifying the (already) amplified signal.
this thread has all the info you need to add (replace) the subs and add an amp. I actually did this right after I got my current HC. It helps, but the deficiencies in the rest of the HK system are still there. My Challenger Hellcat subwoofer upgrade thread
1 - 5 of 5 Posts
