1 - 12 of 12 Posts
562530
2015 auto 8 speed challenger hellcat with 2.85 and pulley...car won’t move when I put it in reverse or drive it says go back to park then dearies gear...days before it stop running my radio bricked a few times and other weird electrical issues
5 year 50K warranty. Are you out of warranty? Or did they deny because of pulley and tune? If it’s not under warranty I would pull it out of there and take it to a reputable transmission shop. The fuel service is just an upsell the brakes are probably close but you don’t need them to do it.
Hard to say. If the fluid is really burnt inside trans it’s likely part of your problem. Did you ask to see if while they had it apart???
that estimate honestly isn’t that bad. My co worker just needed a new trans put in his company Caravan and it was $6850 thru dealer. I had to call about the invoice before I approved it, after spitting coffee all over my desk lol.
BMF
Pulley and Tune Up will definitely show up on dealerships screens
Reactions: Radride
Challenger SRT Hellcat Redeye
If you have already increased HP and need a tranny, and not covered under warranty, I would check with the vendors here and get a built one.
Reactions: WizzaVTX
That's why finding a tuner is critical. The trans either wasn't tuned or tuning was too aggressive. I'm glad I have a manual lol. The only trans tuning available for my car is working out on my right hand.
R.K.
I'm sure there's more details but check out HHP's option.
Some details from Southern Hot Rod's page:
IMPORTANT
You will need to send SHR your transmission for us to build.
After you purchase online, we will contact you to setup pickup via truck freight.
2015-2020 Dodge Challenger HELLCAT
2015-2020 Dodge Charger HELLCAT
Engineered for the most demanding high powered HELLCATS.
Includes-
  • Alto Products G3 Friction material
  • Kolene Steels
  • ZF Bolts
  • ZF Bearings
  • Precision assembly
Our build process...
  • Complete transmission tear down
  • Thorough parts wash
  • Complete and detailed inspection
  • Measure all critical dimensions
  • Full "DRY" stack up build
  • Set friction clearance to SHR specification
  • Valve Body tear down
  • Clean and Inspect valve body
  • Build valve body
  • Bead blast transmission case
  • Final "WET" build
Here is a rebuild kit they offer, also, if you are confident in your own abilities:
1 - 12 of 12 Posts
