Noticed this a few days ago.
www.youtube.com
Is this normal? Foot isn't on the gas at all and it does this.
RPM Reving on own
One of my TPMS on the passanger side is out. i have it on order to be replace. it happens when im 1st gear and slowing down a bit. i just think its odd how it revs itself like that.I have a 16 Cat bought new, automatic.
I see that your tire press is low, also if this is happening while you are turning the wheel, might be due to the PS pump strain as these are hydraulic not electric PS.
What does the idle RPM do if you just sit still and don't turn the steering wheel? The power steering pump does load the motor.Noticed this a few days ago.
RPM Reving on own
www.youtube.com
It seems to idle like normal when sitting still no with no input.What does the idle RPM do if you just sit still and don't turn the steering wheel? The power steering pump does load the motor.
If the idle is stable sitting still and does not surge or roll, then I doubt there is an issue.It seems to idle like normal when sitting still no with no input.
Yeah it isn't the best video. I am going 9-10 in first gear and the car is revving by itself is what my concern is. I have a jeep that when in sport hold after braking a1 higher RPM, however with my HC it seems to rev it and not hold the RPM. I had it in these settings:The video is too jerky and I can't see what the problem is. So you're sitting still or going 9-10 MPH? My 2015 starts up, idles fast for 30? seconds, then settles back down until I start it the next day.
As far as i know its all stock. I bought it used.Any aftermarket intake? Seems like it is "gasping" for air.
Please pop the hood and snap a picture.As far as i know its all stock. I bought it used.
Yeah that is my plan for next week. This car is my daily so i have to find time to squeeze it in.Please pop the hood and snap a picture.
Other thoughts that come to mind are Fuel Rail recall and a PCM flash. It would be good to get it to the dealer for a multi-point inspection.
whats with those recalls? I have a 2016 Challenger Cat, auto, never got those recalls.Please pop the hood and snap a picture.
Cat swap and PCM updatewhats with those recalls? I have a 2016 Challenger Cat, auto, never got those recalls.
Good info, I did get the Cat Convertor recall, but the fuel rail I see is for a 2015 model.Cat swap and PCM update
Fuel rail recall was for 2015.
