41 - 59 of 59 Posts
Have Guns Will Travel
Interesting.
I JUST talked to AEM about the video posted on here showing the stock filter out performing the AEM stock box filter and there engineer department ran some test and it seems I am right they advised me to not install this on my cat they said it seems to fit but doesn't provide enough airflow and there going back to drawing board to see if they can build one. The engineer I spoke to from AEM IS JOEL.... So anyone who has this on there car should be taking it off. The stock filter for this car apparently is really well made and special just for the hellcat
They marketed a product without testing or verifying it met minimum air flow requirements? Won't do business with AEM.
Reactions: 16GoManGoHC
Is the blue line the oe filter on the dyno chart above?
Yes, it really did.
Installed the K&N CAI on BOTH of the Hellcats - it is noticeable and no error codes, engine lights, or other issues of any kind.
OK. So the question everyone has to ask is what did K&N do right and what did AFE fail so miserably on?
Since the AFE intake has been out it has been dragged through the mud and multiple people have even stated they actually LOST power. But this K&N is showing the numbers that AFE had originally advertised.
Edit....re looking over your dyno charts I see the stock run has 33% humidity while your K&N run shows only 18% humidity. That may explain some of the extra power numbers.
DRIVESRT.COM
Weather and, more importantly, engine operating temperatures. That's what is unclear on the dynos I've seen for aftermarket CAIs. I think that is how some of these gains are achieved; having it heatsoaked stock and then running the aftermarket CAI pre-heatsoaked.
I just HOPE nobody plays games during testing by using a less than new (dirty) OE filter. :eek:
I clocked over 2700 miles on my K&N drop in filter and no issues or codes.
On the dyno with the K and N CAI the hood was probably open. So it will get more in. When you close the hood and do a dyno it is probably just about the same as stock.
Did you ever hear back from them? I was just about to order one as I ran the AEM filter on my Jeep SRT. Im glad I just saw that video though. Shocking to say the least. There has got to be something that flows better than the stock paper filter without doing a full intake
Amsoil makes oil-less filters as well but I dont see one for the Hellcat. Just universal sizes. I emailed them too
Same problem with AFE
I saw this posted by [email protected]
I use the green filter and it did pretty good at the track.
We all know the stock filter is the restriction via bench test. Now add a stock filter with 5% blocked by dirt. At least get one you can clean and keep it clean.
one thing I think about when it comes to upgrading my air filter on the hellcat is the heat exchanger. Any dirt or dust that makes it past the filter is probably ending up on the heat exchanger.
Livernios S900 package I got installed a couple years ago includes a K&N panel filter and car makes 750 rwhp with stock air box and intake.
41 - 59 of 59 Posts
