1 - 3 of 3 Posts
Searched all day on here and Google yesterday, so obviously it needs a definite answer posted on the forum.
So I have the adapters and just need a total or what the additional volume above factory would be for the drag kit.....
Discussion Starter · #2 ·
Got an answer, so it will be officially documented......
50oz TOTAL
48oz straight r134a without oil
2oz oil
thank you @16GoManGoHC
50oz TOTAL
2oz oil
This is for the drag size unit with drag valve installed.
Heres my pressures in around 70F ambient idling with that charge amount.
A suggestion to be leak free, add a thin coating of loctite 554 Refrigeration grade sealant to the male flare surfaces before your final tightening of the fitting. Not on the threads, on the flare surfaces otherwise you will loose gas through them. My system still fully charged almost 2 years later.
1 - 3 of 3 Posts
