I have not heard complaints about any long-tube header brand, but if you like catalytic converters, Kook's (pronounced cooks) makes "green" cats with higher flow rate, and people like their results with the Kook's. They also come in a couple or few different primary tube sizes, and they make an exhaust system to match it.
If you really want power in a 392, you are going to need revs, and having said that, talk to a reputable tuner, but the 2" tubes will not be a limit on upper-RPM power.
I like the way you are thinking, though. A cam and header package with a tune are going to yield results you can feel (and hear) and I assume you did not get this thing to set fuel mileage records, anyway.
Ported heads, an aftermarket high-RPM setup (reciproTating assembly and cam, pushrods, lifters, valves, springs, retainers,) Add one of
@hpindy's lower-rpm accessory pullies on an ATI damper, or a "30 percent lower accessory belt speed" pulley from some rando maker that also produces a 7 percent lower for the Hellcat (I have a thread on it, don't know if either will go on an ATI for the 392) and you should be seeing substantial hp both made and freed. Amsoil for all lubrication fluids will increase your power output further, but break in the oils for a week or two before hitting the dyno.
Cold air intake, such as the one for the Hellcat or one ported to hood scoop from Mopar will provide no negative results, also insulating the intake from heat.
Ok I will be coming into some money because of a new job. My goal is to get my challenger into the 700-800hp range and be as fast or faster then a hellcat. My budget us up to 20k but I would like to be closer to 15k if possible. What I need is some feedback on shops on the west coast that can...
www.challengerforumz.com
