Just finishing up getting my mostly stock 2020 HC tuned (has Borla ATAK, LMI and 180 thermo).
As always looking for just a little bit more but don't want to spend a fortune or lose any of the amazing drivability I have.
Thinking about adding a 10% over lower ATI. I feel I need to pin the crank anyway so might as well put the ATI on at the same time. I do not want to do an upper. Tight winding of the belt, additional idler pully etc is not what I want. Also,
you can not see the lower. Do not want to go to bigger injectors or fuel pumps. Just a couple of lbs of extra boost would be nice.
So my question is if I go with only a 10% lower do I have to change injectors and fuel pumps or will the stock stuff handle it? I know I will have to tune again and I am good with that.
Thanks for your Time,
Varooom
Varooom
