Curious, I am, as to how/if they will package that bambino up for the Hellcats. If it's another drop-er-right-in package like the 2650, it'll be a serious contender for the Benjies.
Eaton already produces an uberstuffer for the Cravatte or however you spell it LOL that has 3.0L displacement. My guess is that since this already exists:
...that Magnuson is working at engineering their own cases etc. to use with said Eaton internals.
I ask again, what is the RPM potential of this sucker?
I wonder if supercharger makers have considered alternative materials for their rotors for reduced rotating mass or increased strength. One has to remember that those rotors see a LOT of heat and need to dissipate it and/or not absorb it in the first place. Carbon fiber looks good, to me, based on rigidity, low coefficient of thermal expansion, and thus rev potential.
BUT, the surfaces of those rotors would be seeing a lot of heat that had no way to escape, as carbon fiber is very effective at insulating heat transfer across the fiber, though it conducts it ALONG the fiber just dandy, rivaling copper, and, of course, exceeding it past copper's melting point.
Titanium is the material of choice for very-high-output turbochargers due to it being stronger, in spite of higher mass, than aluminum, even carved billet aluminum.
The primary stress on turbo compressors is the blade working against the air, as powered by the shaft, not the centrifugal forces of rotation, or ceramic blade compressors would be the answer.
Another concern with carbon fiber is that due to its low hysteresis it can have harmonic vibrations start to build that keep increasing in magnitude up to the point of destruction. Aluminum is naturally good at vibration damping, as it has a fairly high hysteresis. No one, like literally nobody ever, uses aluminum for a material in making bells.
Resonance in mechanical objects is your enemy. Mythbusters put a little device with an oscillating weight on a steel bridge once and set it to a certain frequency, and it had the entire bridge vibrating. They shut down the study and kept hush hush about the frequency, and said "Don't try this at home."
If resonance is a potential problem, such as in the construction of a driveshaft, carbon fiber is not the ideal choice. Whether the vibration is torsional or linear, it can escalate like a rumor and lead to failure. Spicer markets driveshafts that are combination aluminum and carbon fiber. most likely for that very reason.
