Manual hellcat mods.
5543 Views 43 Replies 11 Participants Last post by  16GoManGoHC
I have a 2015 m6 hellcat, and my best 0-60 time is 4.7 seconds with toyo r888r’s and kw coils. My issue is I baby the car. I bought it with 800 miles, and it currently has 11,000. I haaate slipping the clutch, and dumping it leads to wheel spin.
I never take to the track, but regularly tear it up around local windy roads and light to light races.
I’d like to get my car performing better, but I DON’T want to sacrifice reliability. I’m thinking about swapping my rear end out to a 3.90, but It seems like it may not be worth it. I want to run pump gas, so I don’t know if a pulley would be wise... Are there any mods that may help me out? Any guidance is appreciated!
1 - 20 of 44 Posts
I have an 18 M6 WB. Still under warranty not sure if that is an issue. If not @greasy can advise you as he has a 840whp M6. If so for me Barton shifter, Fastman TB, Pedal Commander, Lowering Springs, 190° Tstat, Legmaker CAI, and biggest was 315 555r2's. More air, ability to put the power to the ground, better throttle response, and no wheel hop have made this a whole different car thus far. You can definitely get 800+WHP on a pump gas build as well.
Reactions: 2
Listen to @Beast707 as he told me he hits sub 3.0 60' times..🤙
Oh wow, I had never entertained a couple of these mods. A pedal commander to me seemed kind of like snake oil, and I’m leery to pound through the gears and damaging synchros. But you think they’re really worth it?
You definitely notice a difference with the PC. I thought the same way until @Octanewide sold me on it. Recently had to take it off for a week and let's just say I'm so glad it's back.
All a pedal commander does is change how the throttle blade opens in relation to the position of the accelerator pedal. Essentially giving the illusion of more part throttle power.
Some like it. Some think its a waste.
Tuning of the electronic throttle can be done with hp tuners, so a commander would be a waste of in that instance.
Some easy mods:
Intake
skip shift elimator (can be turn off with hp tuners)
No point in modding if you don't even like using the power it comes with. IMO
Reactions: 2
I have a 2019 M6 HC with a 7 year B2B extended warranty and beat the living shit out of. You cannot take this thing with you so enjoy it as designed. FWIW, I set money aside every month for a new clutch because that day is going to come.
My best 0-60 on the stock summer tires is 3.2s. My only time at the track on a drag radial netted a 1.9 60'. I need more seat time to improve the launch.
More gearing will aid in getting the car moving easier. These cars would need 4.something from the factory, with a proper 5th and 6th gear for highway cruising if it were drag-only; but they aren't. They are track ready, 200mph capable, and great GT cars. One. Big. Compromise.
Mods?
Barton. Clutch delay valve delete. Take weight out of the car. The difference in driving the car loaded with my whole family onboard (wife, kids, car seats, full tank) and driving the gutted (seats out, drag pack, sway bar off, 1/4 tank of gas) is immense.
But mostly it needs the driver mod.
Reactions: 2
Some easy mods:
Intake
I do like using it, I just don’t like abusing it. Giving it hell once I’m off the line is awesome. I just don’t want to oblitera
Some easy mods:
Intake
i love using the power it has. I just don’t like slipping the clutch to get off the line. That’s why I was looking at the differential to help make the power a little more usable for me. Ya know?
Mods?
I definitely agree with the driver mod! Lol. I’m trash. For the time being I have some pennies to throw at stuff to make it perform a little better
I know what you mean about getting off the line. The real problem is first is WAY too high, for daily use that is anyway.
Btw going from 3.70 to 3.90 is about 5% difference, too small of a change for what it is. Especially when you look at the scat pack 1st gear. Hellcat has about 30% higher first gear, than the scat pack/srt392. You would have to have at least a 4.80 (not possible) to even come close to the scat pack/srt 392. But that would hurt cruising rpm because 6th isn't high enough in the first place. .no pun.
-Insert A8>M6 jabs here- 😂 jk
Lol! The thing is, I’d trade being slower for the amount of fun I have in the canyons. It’d just be nice if I could get going faster while still babying my car.
Not sure if the 3.90 would do much for launching the car but it does make it a bit more driveable. You can still run pump gas with a 2.85 pulley but you may run into warranty issues if you break something.
Yes, but extrapolate that 5% over the four gears used in a drag race (or all six in a half-mile), how it impacts torque multiplication, and the acceleration rate. It will make a difference.
For $800 it might be worthwhile.
Seems like the if you want to run with the A8's one of the best options to get you there is the Transzilla. Trans gearing is our bugaboo.
Reactions: 2
If you worry about 0-60 performance and yours already stinks then adding a pulley and making more power will not cure the problem....it will only magnify it. The best 0-60 I’ve managed with my car so far is a 4.2 and that is slipping the clutch/feathering the throttle on R888R’s. Now I haven’t practiced a ton, but I for sure need to practice more as there is more in it, but it is tough to do with this much power on tap and a banger car. That is part of the fun though!
Reactions: 2
Well said..😁
Reactions: 2
@Beast707 can show you his routine as he has told me about sub 3's sixties 🤙
Reactions: 2
Lol! I tell him I'm out Hookin & Bookin and he asks my 0-60 everytime lol. So had to tell him 2.9 because he knows I've never even done a burnout! @greasy we need to find some Mexico out here so I can and shut him up! :cool:
Reactions: 2
Hahahaha you guys always busting each other’s balls!
Reactions: 2
2
A lower gear Tranzilla is the way to go. I run a 2.98 first, 2.10 second, 1.43 third, 1.0 fourth, .85 fifth, .63 Sixth its a bit steep on the street but at the track on a 315/50-17 is perfect. I pull about .85G sometimes 1G on the street with the 315/35-20 Nitto NT05R with a best 11.2 street 1/4, no more slipping the clutch, now it’s all in throttle control on the street. I run a 2.85 with a massaged blower and other goodies. At the track it’s dump the clutch and roll the throttle to the floor, the car normally runs 10.6-10.8 but had 1 fluke 9.998 pass on a super sticky competition prepped track, launched hard and power shifted ever gear perfectly. But if I could spend my money all over again I’d buy a Redeye.
Took 2 summers to get here and a bit of cash, going fast with a M6 is easy, being quick isn’t, being consistent about impossible without ALLOT of practice. BTW, I’m still on my original stock clutch, have 2 new ones on the shelf though waiting for the day but so far 13,500 miles and a bunch of street and dozens of track passes and still going strong.
Text Receipt Font
Text Line Parallel Design Diagram
Reactions: 5
1 - 20 of 44 Posts
