1 - 11 of 11 Posts
Anyone have experience with running the 3.2 size Metco pulley? 1-1.5 PSI increase. Just a little bit smaller than stock 3.35 size. Just curious. Thanks in advance!
2015 Charger SRT Hellcat
I and many others are running the 3.10 Metco with a 10% lower pulley
no issue with it from any experience I have had......makes the power go round and round
Mid-14 lbs of boost with my setup and tune on 93 fuel
Nice! I wonder if just a 3.2 alone would be ok without a tune. Metco mentions on their website that people have done this
Reactions: 2fast4u
Have seen it written about from others doing it.
Doubt highly anyone would really notice and don't encourage it.
Discussion Starter · #5 ·
Yeah, probably not worth the chance. Will eventually go 2.5 with dual fuel pumps, injectors, e85 and a Dusterhoff tune.
Reactions: 2fast4u
That is a pretty far stretch from 3.10 swap and likely a solid performer for the track...not sure about driveability....that is a very small pulley on top. Mine is not running E, and I don't honestly see it in my future. Might want to look into other strengthening items like ARP studs as well as other items to keep the setup cool.
May be a better option to just go with the Incognito lower pulley without pinning the crank and gain 2-2.5 psi. This will keep belt slip at bay and give a little more power.
Discussion Starter · #8 ·
The 3.10 upper and 10% lower you’re running is the equivalent of a 2.75 upper by itself. The 2.50 plan I have would be a ‘strictly track’ setup, and plan to run a 2.75 by itself normally. So around your level. How do you like the difference it’s made?
Is there somewhere I can see what combos give you? For example, 10% lower with 2.95 upper.
Discussion Starter · #10 ·
Here are a couple charts: the images just show safe RPM levels based on pulley setups, but can give you a relative idea comparatively.
578759
578760
1 - 11 of 11 Posts
