1 - 8 of 8 Posts
I just placed an order for one since it’s not available here in Kuwait. I have a few questions:
  • Will dust enter the filter?
  • The filter is dry? How long does it last?
  • The single way valve means that pressure out but no air in right?
  • Does it work with JLT Dual Driver-Passanger Side Combo Catch-Can?
https://www.metcomotorsports.com/proddetail.asp?prod=MBR0019
Thanks in advance
SG
Reactions: [email protected]
No dirt will enter filter and filter is dry other than any mist it might get. One way valve only allows pressure to escape. They work great barely a drop of oil in my catch can and I think it's because the breather helps balance pressure.
Don't know on the JLT question,
Yes, I have a Metco with JLT dual catch cans, and they all fit
Super Moderator
Super Moderator
https://www.highhorseperformance.com/Metco_Valve_Cover_Breather_2015_Hellcat_Vehicles_p/mbr0019.htm
HHP Sales Contact number Toll Free: (888) 894-1115
This breather installs as a direct replacement for the OEM oil fill cap, and absolutely no modifications are required. The precision-machined helix in the bottom of the billet stand fits tightly into the fill tube, and the seal is maintained by the included o-ring.
In supercharged applications, combustion pressures invariably find their way into the crank case, and this pressure contributes to pumping losses, elevated oil temps, and premature failure of engine seals. The breather serves as a high-flow vent to allow any pressure that builds to easily vent into the atmosphere.
This breather is fitted with our proprietary APV one-way check valve, so while internal pressures can pass through, outside air cannot be drawn through the breather and into the inlet tract of the engine. Your engine tune will not be affected by the installation of this breather.
Like all Metco breathers, this unit is CNC-machined from 6061 aluminum, and micro-finished on the exterior surface. The filter is a high-quality reusable unit manufactured in the USA by S & B filters.
Total installed height is less than 3". This breather may not be legal in all states.
For earlier Gen III Hemi applications using a screw-in style oil cap, please see the MBR0012 breather listed elsewhere in this section.
Super Moderator
1 - 8 of 8 Posts
