RPMs would be 6,500, 6.200 connecting rod length on a 4.00 Stroke Crankshaft. I went with a 422 over a 426 mainly to have a better rod angle.There are a few variables to to pin a HP rating on rods. Engine RPMS, rod angle, piston/pin weight, etc
That should be the information a engineer at Molnar will need to give you an answer, hopefully.RPMs would be 6,500, 6.200 connecting rod length on a 4.00 Stroke Crankshaft. I went with a 422 over a 426 mainly to have a better rod angle.
They’re H-beam
I think your best bet is to contact Molnar and speak to them . Their rods are really good ( I have a set in my engine) .RPMs would be 6,500, 6.200 connecting rod length on a 4.00 Stroke Crankshaft. I went with a 422 over a 426 mainly to have a better rod angle.
They’re H-beam
I agree with this .They are H beam probably around 1000-1200 or so. I beams you can squeeze more out of them. The problem with H beam is that they tend to split in the middle and almost looks like they get delaminated. They are great for 99.9999999% of the cars that are on here for a rebuild. Never checked, but how many main bolts are there?
Yeah, that would consider a 4 bolt main.I agree with this .
Also the gen 3 Hemi is a cross bolted block mean it had 2 main bolts in from the bottom and 2 smaller ones in from the side on all 5 main caps .
How much rwhp are you currently at?I think your best bet is to contact Molnar and speak to them . Their rods are really good ( I have a set in my engine) .
I don't know as I have never dynoed the car . But I will be at the track this weekend so I will tell you how it does in the 1/4 mile .How much rwhp are you currently at?
Interesting, I was alway under the impression that H Beams were typically better but this is from seeing my dad build motors 6-7 years ago on SBCs.They are H beam probably around 1000-1200 or so. I beams you can squeeze more out of them. The problem with H beam is that they tend to split in the middle and almost looks like they get delaminated. They are great for 99.9999999% of the cars that are on here for a rebuild. Never checked, but how many main bolts are there?
Sounds good! Saw your signature and those are some great times. Definitely let me knowI don't know as I have never dynoed the car . But I will be at the track this weekend so I will tell you how it does in the 1/4 mile .
I always post time slips in my build thread.Sounds good! Saw your signature and those are some great times. Definitely let me know
Molnar Rods work fine in my Redeye. I like rpm's. Stock cam is probably out of power range at 6500 but i have it shift at 6850. Car runs 9.60's on E85 at 4800lbs. After doing a search on Tom Molnar. I knew i was buying Molnar rods and crank for my engine. He has been in the Connecting rod business for many years.Sounds good! Saw your signature and those are some great times. Definitely let me know
I know they’re a reputable brand but just like anything else, they do have a limit.Molnar Rods work fine in my Redeye. I like rpm's. Stock cam is probably out of power range at 6500 but i have it shift at 6850. Car runs 9.60's on E85 at 4800lbs. After doing a search on Tom Molnar. I knew i was buying Molnar rods and crank for my engine. He has been in the Connecting rod business for many years.
