1 - 20 of 20 Posts
2021 smoke show WBRE 3.09’s
Just wondering what are the best mods or should I leave my redeye factory. Are there any intakes that will improve a redeye? And what tuner and injectors are the best?
All depends on your end goal and fuel choices. Intakes sound cool that's about it.
Sent from my SM-N986U using Tapatalk
Discussion Starter · #5 ·
Can you look up this video and tell me if this guy is full of shit? He says he only did a few mods.
Yeah so need to determine who is going to tune it which will determine quite a bit of what you do next. If you're in New York AJ or Curt and see what they recommend for setup.
Discussion Starter · #9 ·
best mod out the gate, that doesnt mess with your warranty or resale value DtR would be proper tires.
dodges factory selections, flat suck
Would a straight pipe and headers do anything for performance?
Will a tuner void factory warranty?
Literally anything other than tires is going to void your warranty. How bad does low 11’s/high 10’s out of the box really sound? Some dont care about losing the warranty but if youre asking i’m guessing you might.
2020 M6 HC
Splash guards. I went with OEM but there are other options.
65 GTO, 21 REWB Challenger ordered
So those are non widebody of course. Perhaps there's no widebody OEM guards?
2017 Dodge Challenger Hellcat
I honestly believe it, my car made 715rwhp on a Dynojet and I ran a 10.39 at 132, that car on 18-20psi with E85 has to be making over 900whp. The redeye blower is already bigger which makes it more efficient when it comes to generating less heat, I believe from the factory they put out 15psi. 180whp more has to be good for at least a whole second in the 1/4mile
Discussion Starter · #17 ·
Ok so what mods did you do? Also what tires you like? Are Michelin ok?
Mods - ID1050x injectors, 2.72 pulley, AFE intake, 100mm Throttle Body, Catless, DSS Driveshaft, Kenne Bell boost a pump on 91 octane. car has no timing in it for safety since I'm running 16 psi of boost
Tires - I run a 17 inch weld S71 with a 305/45 Mickey Thompson ET Street R with 20psi
If you want to post a good time I recommend getting a set of wheels and tires for racing. If you daily your hellcat like I do, you need to have a good set of all seasons on all the time. Radials and slicks aren't good for any weather condition other than dry, very dangerous in the rain. If you get a set for the rear you can just swap them as you please when you go race. a Michelin depending on the tire compound and type will only get you so far. you'll need a dedicated drag tire if you want the best times. I recommend the ET Street S/S if you don't daily and want race on the stock 20inch, but if you want a race set I recommend an 18ix10nch, if you go 17x10inch you'll need to install shorter sway bar end links(easy job) use a ET Street R tire 18-22psi you'll hook no problem at the track.
Discussion Starter · #19 ·
I was told there was no aftermarket intake better than the factory one on a redeye
1 - 20 of 20 Posts
