Modding a scat pack can be a sketchy journey. If you are looking to achieve those numbers the safest/cheapest way would prob be buying a hellcat. Most FBO e85 scats will make around 450ish wheel NA. That includes throttle body, flex fuel kit, full exhaust, ported intake manifold throttle body,injectors, fuel pump and more and right there is a couple thousand. And if you were to go a boosted route like a procharger or whipple your looking at an easy 8-10k installed. Also tuning is required and is a pain because you need to buy a new ecu or have yours unlocked. With the Fbo and the boost added you will be around 500-550 wheel but unfortunatley at that power level, the integrity of the motor can be at risk because the 392s like to blow at 6-7 pounds of boost. In conclusion, it is possible but is very costly, and there is a lot of risk, therefore purchasing a hellcat might be your best bet. Btw hellcats stock make around 620ish wheel. I cant tell you the amount of people that went ahead modding their scatpack, ending up rebuilding the motor or swapping it with a 426 and at that point its a money pit. Hope this helps friend!I have a scat pack I’m trying to get 550 RWHP N/a or 530 some close to that what can I do too it
And I can easily tell you that I know triple the amount of people who tried to modify their scat pack and it never ran right again. They usually end up just buying a Hellcat. One of these days I'm going to out this guy, because I've talked about him a half dozen times here. He is a moderator on a Challenger FB page. He paid a shop to do an air ride and ProCharger on his scat. Well, the shop talked him into stroking it to a 440, going wild on some of the internals and put on a much larger D trim ProCharger. He claimed it was a 1,000rwhp build... but knowing what I know about D trim ProChargers, he was likely pushing 850-900rwhp.Modding a scat pack can be a sketchy journey. If you are looking to achieve those numbers the safest/cheapest way would prob be buying a hellcat. Most FBO e85 scats will make around 450ish wheel NA. That includes throttle body, flex fuel kit, full exhaust, ported intake manifold throttle body,injectors, fuel pump and more and right there is a couple thousand. And if you were to go a boosted route like a procharger or whipple your looking at an easy 8-10k installed. Also tuning is required and is a pain because you need to buy a new ecu or have yours unlocked. With the Fbo and the boost added you will be around 500-550 wheel but unfortunatley at that power level, the integrity of the motor can be at risk because the 392s like to blow at 6-7 pounds of boost. In conclusion, it is possible but is very costly, and there is a lot of risk, therefore purchasing a hellcat might be your best bet. Btw hellcats stock make around 620ish wheel. I cant tell you the amount of people that went ahead modding their scatpack, ending up rebuilding the motor or swapping it with a 426 and at that point its a money pit. Hope this helps friend!
It's more expensive to build out a Scat Pack than it is to buy a base Hellcat. Either the engine work will cost you a lot for an NA build, or the supporting mods needed to run FI will bury you. If you do pistons/rods and a blower, you'll also need a rear diff and a transmission. Either way, you're looking at around 20 grand. On an NA build you'll get somewhere in the 500 range, give or take. On an FI build for the same cost... around 700 to the wheel on a conservative, streetable build.Thanks so much I thought it would be possible I have a 16 ss and I got 535 too the wheel I just got a wide body scat pack charger and figure I could make a sleeper out of it but thanks it’s not worth me spending money in it to only get 450 ish to the wheel a want a hell cat but lord knows the new ones are so expensive
It's cheap insurance until you try to file a claim with a highly modified car. The instant that adjuster gets wind of the fact that it's supercharged... they drop the coverage if the mod wasn't reported. If you do report the mod, they cancel your policy at the renew date unless you have specialty insurance. On my 1,024whp Mustang, I had comprehensive and collision with GEICO, but with a rider that said the engine and drivetrain were not included in the policy. I had to take out a second policy to cover the engine and drivetrain. I was paying in excess of $1,500/mo for that car's insurance.There sure is a lot of truth spoken here and you should listen.
I have a 300 that I was building, "still am", then bought a Trackhawk. Everybody in my life said to just put 300 back to stock and sell all the stuff, you have a Trackhawk. Nope, I'm hard headed and love the 300, so I continued on, you can follow along in the LXforum, "Whipple build". I call it the money pit now. Pain in the A$$, but I love the car. Advantages, cheap insurance.
Save your money, drive the Scat, then trade up to the Hellcat. In the long run you'll thank everybody here.
Exactly. You can't buy a 300 Hellcat, so modding is the only way, the route I took.I've come to the conclusion that a used Red Eye is the way to go, you shouldn't have to change out as many parts so you won't spend a fortune.
If you want to make your own street legal funny cat get an R/T or 300S, they share the same platform and if you end up messing it up, a 2016 probably ran you less than $20K depending on condition. I can understand someone buying a Scatt and over time switching parts out but to spend $50K on a car then spend another $25K to make it a car that you could buy for $75K already seems to be a lot of wasted time, money, and assumes risk.
I have 502 to the wheels and I have throttle body, an after market intake manifold, long tube headers, intake, custom grind cam, thermostat, hellcat oil pump , and a dyno tune total cost me 8,579Modding a scat pack can be a sketchy journey. If you are looking to achieve those numbers the safest/cheapest way would prob be buying a hellcat. Most FBO e85 scats will make around 450ish wheel NA. That includes throttle body, flex fuel kit, full exhaust, ported intake manifold throttle body,injectors, fuel pump and more and right there is a couple thousand. And if you were to go a boosted route like a procharger or whipple your looking at an easy 8-10k installed. Also tuning is required and is a pain because you need to buy a new ecu or have yours unlocked. With the Fbo and the boost added you will be around 500-550 wheel but unfortunatley at that power level, the integrity of the motor can be at risk because the 392s like to blow at 6-7 pounds of boost. In conclusion, it is possible but is very costly, and there is a lot of risk, therefore purchasing a hellcat might be your best bet. Btw hellcats stock make around 620ish wheel. I cant tell you the amount of people that went ahead modding their scatpack, ending up rebuilding the motor or swapping it with a 426 and at that point its a money pit. Hope this helps friend!
How long has it been?I have 502 to the wheels and I have throttle body, an after market intake manifold, long tube headers, intake, custom grind cam, thermostat, hellcat oil pump , and a dyno tune total cost me 8,579
