My Challenger Hellcat subwoofer upgrade thread
42797 Views 48 Replies 18 Participants Last post by  jkviper
I’ll am providing this documented process if anyone wants to do something similar. There are a few similar threads and I used them to help me plan my install so I figure this may be helpful to others. Happy to answer questions. As of now, the system is installed and I am happy with the results. I still have to finalize a few things and will add some more pictures for completeness.
Basically upgrading the factory Harmon Kardon subwoofer with JL Audio and a JL Audio amp to better dial in the sound the way I like. Overall I think the HK sound system is great, the main change I wanted to make is to provide more low bass(more kick/punch) without making the overall sound have an overwhelming amount of bass. I like the punch with Plus 3 on the bass, but then the overall sound had too much bass for me.
To accomplish this I chose JL Audio 10W1v3-4 subwoofers and the JL Audio RD500/1 mono amplifier.
The subwoofers are 4 ohm single voice coil units and the amp has bass boost, speaker level inputs and can turn itself on by sensing power to the speaker wires. No other signal processing unit is needed because of these features which simplifies the install. The bass boost enables the volume adjustment of sub 20 hertz bass. Sub 20HZ bass is the punch/kick control I am looking for.
I’ll be adding more to this thread as I have time....
Reactions: 5
1 - 20 of 49 Posts
Be sure to take plenty of pictures
I’m interested in seeing the finished project. Following
1st step, remove the subwoofer box. There is a 10mm bolt on the left side of the subwoofer box which needs to be removed. Also remove the spare tire like holder which spins off. Finally disconnect the sub wiring harness. Then simply lift the sub box up and out of the trunk. It is surprising light, the sub woofers weigh only about 2 pounds each. The new subs with much larger magnets weigh in at about 11 pounds each so this upgrade will add 25 pounds to the rear of the car when including the new amp.
10 mm bolt
Electronics Technology Auto part Electronic device Audio equipment
Sub harness
Technology
You can see the round plastic holder which needs to be unscrewed-removed.
Vehicle Car Automotive exterior Auto part Automotive window part
piece of cake, removal could not be any easier.
Fictional character Vehicle
Looks good. JL audio has some of the most badass subs in the industry. I have no experience with their car systems however I do have their subs in my home theater. All the best.
Next step is to remove the HK subs from the box, create a new sub wiring harness and install the new subs.
There are many ways to wire the subs up. I decided to modify the sub harness and use them as an input into the amplifier. That way I could solder the two plastic connectors back on, an easy modification to put it back to stock. I did not want to splice into the main harness. You can see the grey end attaches to the main harness and the 3 connectors go to the subs. The factory subs are dual voice coil so two connectors go to the left most sub and the other goes to the right sub.
Also notice there is a thick rubber grommet which plugs the wire hole up and passes the wires out of the sub box. I did not want to cut that up so I found a tapered rubber stopper that fit perfectly for the job. There will be more detail in the next post about how I modified the harness etc.
Below is a pic of the factory subs and wiring harness. Amazing how light these subs are, I think if I left the HK subs in the box and just added an amp I could come very close to the improvement I wanted to make. But never bothered to take that approach and went for new subs.
Auto part
Empty sub box, I shaved down the little raised nubs where the factory mounting holes are located so the new subs sit flush.
Auto part
I ran two sets of speaker wire through my new grommet. The thin side will be pushed through the hole in the sub box to pass the wires through
Wire Technology Cable Electronic device Electrical wiring
I soldered a 4 wire auto connector I bough on eBay so I can easily detach the sub box just like stock
Wire Electrical wiring Cable Technology Electrical supply
Added some poly-fill to help dampen the subs
Audio equipment Electronics
Wired up the new subs, they fit perfect from a depth perspective. The only issues is they have 8 holes where the factory has 6 so you have to make additional holes in the sub box. I used #8 3/4” self taping plastic screws and they worked fine. Just be careful not to over tighten them, the plastic in the box is not all that thick and you could strip the holes if you are not careful. I recommend hand tightening them.
Wired up the subs to the new sub harness
Audio equipment Technology Auto part Electronic device Personal protective equipment
Self taping screws
Screw Fastener Auto part Metal
Material property Font Technology Label Electronic device
The new subs are now installed in the box, notice how the new sub wire harness is installed as well. Looks pretty good.
Car subwoofer Subwoofer Loudspeaker Vehicle audio Audio equipment
Reactions: 5
Looks great!! I was thinking of going the adding a amp route. What would you suggest?
Thanks, sounds great too, just haven’t finishing posting all the pictures. As far as amps go you want to select an amp that delivers the recommended continuous amp rating RMS value.Crutchfield has a number of articles on this.
I would not know the right amp to power the stock subs since I don’t know anything about them, but would assume a lower end amp would work.
I would look for the features that I found in the amp I selected, it has bass boost, variable frequency settings, and high current speaker inputs with auto turn on.
Very good and informative thread. Bet it sounds great
Below is a pic of the factory subs and wiring harness. Amazing how light these subs are, I think if I left the HK subs in the box and just added an amp I could come very close to the improvement I wanted to make. But neve bothered to take that approach and went for new subs.
Self taping screws
How does it sound
Thanks for the info!!
Were the HK subs stuck in your box? I tried removing mine so I could add polyfill to the box but they seemed to be screwed and glued in. I was being somewhat general so I did not break anything and figured I would ask if there was a trick to popping them out? I left the box in the trunk so it may be easier if I remove the complete box maybe. Great write up. I’m thinking of adding some phenoix gold 12’s along with the stock subs and am researching ways to go.
Hi, the stock subwoofers were only held on by the screws. With that being said, I did have to apply some pressure to release them from the sub box. There is a plastic tab that aligns each sub so it may need a little help with a large flat screwdriver to break it loose.
6
The next step was to modify the sub wiring harness. This mod swaps the existing speaker connectors with RCA jacks. So what used to be input wires to the subs are now speaker level inputs to the amp. Also, there is a switch setting that tells the amp the input to the amp is high voltage and when it sees that the speakers have been turned on, it in-turn powers up the amplifier, It works perfectly.
Here is my understanding of the wiring harness, I used some information found in another thread and extended that information from the main harness to the sub harness:
Purpose => Main harness color => sub harness color
Sub 1a positive => Gray/Brown => Solid Green
Sub 1a negative => Green/Orange => Solid White
Sub 1b positive => Gray/White => Solid Red
Sub 1b negative => Green/White => Solid Orange
Sub 2 positive => Gray/Red => Solid Blue
Sub 2 negative => Green/Orange => Solid White
The stock subs are dual voice coil and the driver side sub has both coils wired while the other sub had only one of the coils wired. I chose to use Sub 1a’s wires and Sub 2’s wires as input into the amp. Here are some pics...
Two wires for Sub 1
Sub 1a wires
Technology Cable Electronics Electronic device Finger
Sub 1b wires
Light Finger Hand Plastic
Sub 2 wires
Text Finger Material property Hand Technology
Subs with the sub harness
Auto part Table Camera
I clipped Sub1a and Sub 2 wire connectors and used those wires as inputs into the Amp. On this amp I had to solder in speaker wire to RCA adapters onto the sub wire harness. Here is a pic of the finished harness.
Technology Electronic device Cable Wire Linens
Time to put it all together....
Installed the sub box with the new JLAudio subs
Audio equipment Vehicle audio Subwoofer Auto part Technology
The amp is all wired up, positive 4 gauge wire(blue) goes from the positive battery terminal to a large fuse(supplied in the amp kit) then into the amp. The 4 gauge ground wire(gray) is connected to the grounding bolt to the right of the battery. When you wire up the Amp disconnect the grounding terminal located on top of the battery to prevent shock.
Here is a pic of the amp installed in the right rear of the trunk. The Amp output wires have been connected to the male end of the new sub wire harness. The RCA amp input wires come from the modified factory sub wire harness. You can see all the adjustment dials and switches on the amp. You can boost the lower bass(I chose +8 dB), change the crossover frequency(I chose 60 HZ) specify how the Amp turns on(I chose to turn on when a low signal is detected).
Electronics Electronic device Technology
As it looks now with the floor panel reinstalled. I’ll probably run the wires through a gray cable flex tube to clean the look up.
Cable Technology Electronic device Electronics Audio equipment
Now that I’ve been listening to the system for a couple weeks I can honestly say I enjoy the sound system very much. I found no need to run a remote sub volume knob. If you want more or less bass you can always use factory equalizer. I just find the overall sound is cleaner/clearer and not muddy. The new sound has clean deep bass.
Hope you enjoyed my build thread!
Thanks for taking the time to put this together. Going to use your info and do something similar.
Just curious, how do you have the amp secured?
I mounted it to a board under the carpet. Screwed the amp into the board. Here are a few more pics.
I cut up a thin piece of plywood...
Wood Cutting board Wood stain Plywood Rectangle
I had some Velcro lying around and used the fuzzy side so it did not rattle against the metal surface under the carpeting....
Tile Floor Slate Rectangle Asphalt
Slipped it under the carpet...
1 - 20 of 49 Posts
