1 - 12 of 12 Posts
2019 Charger SRT Hellcat
hi my friends i want to know what could happen to the supercharger that will made it lose all the oil inside it . if any one know what are the reasons
this what i had 馃槩
i was driving safely suddenly the car stopped and there is no codes or anything
570909
2016 Bright White Challenger
this what i had 馃槩
Are you sure its lost all of its internally stored oil? What does the coolant tank for the blower look like? (the one near your passenger side corner of engine bay)
2017 Challenger Hellcat
Kinda looks like bearings went and were ignored and let some movement happen of the rotors and they started eating eachother up and into the SC case with movement from bearings being gone. Tolerances there are super tight. The actual oil in the innards looks like normal oil coating from a SC with no catch can and hard miles
Kinda looks like bearings went and were ignored and let some movement happen of the rotors and they started eating eachother up with movement from bearings being gone. The actual oil in the innards looks like normal oil coating from a SC with no catch can and hard miles
Was going to say something similar to this but didn't want to be guessing. I doubt the oil had any way to get out, its a closed system and you'd know if oil got out.
2020 Challenger Hellcat
Yeah, definitely looks like bad blower bearings and... what's the air filter like? Because I know desert sand quite well, and that sort of looks like it's got some sand in it too.
Discussion Starter · #7 ·
i got a legmaker intake and yeah we got sand weather this past days
Discussion Starter · #8 ·
thanks for helping. but am in a hard miles yes in 140,000KM and when i got to 100,000 i have cleaned the supercharger and i change everything i did a heavy service for every little piece in that engine and about the catch can i got in the car since in got in 40,000 it's a double catch can馃槉 i tried my best to keep my engine and the supercharge in a gd and safe position. but that happened for my bad luck i think
Discussion Starter · #9 ·
it's the original ones i didn't change them
Discussion Starter · #10 ·
if i got a new pulley is it got to do some damage like that cuz i got a new 3.17 upper pulley and ppl say it's nt necessary to program or but the in the dyno
Discussion Starter · #11 ·
if the sand is the problem should i find some sand inside it and i think if there is some sand did this it could get repaired right
You always need to be tuned when changing pulley sizes.
That supercharger im betting is garbage and will need to be replaced.In reference to the sand, I wouldn't be running an aftermarket filter combo personally, or at least not one without a pre-filter sock to do anything I could to get rid of the sand. Makes me wonder if sand worked it's way into the bearings and helped cause this.
1 - 12 of 12 Posts
