161 - 180 of 203 Posts
This is ridiculous. I can not read the wot box now. Ive tried every port. Deleted everything and re installed. Downloaded the usb driver again.
Wtf do I need to do to get this to work???
Where do you live I can help you if you close or you can call me. It's a real pain in the ass.
Ya that's a tad far from me. I'm in Colorado. I'll send you my phone # and we can talk that way if you want.
Reactions: leadbedr
Is your car running?
Tell me about your wiring.
Tell me what happens when you plug your box into your pc
When your car is on do you have a blue light on your box?
I didn't install it. But it was working the other day. Now I plug it in my laptop, 4 different USB ports, and it says can't communicate. I know it sees it, because when I change ports, it changes the comm selection on the software.
Just won't communicate
What software are you running?
So I had the same problem with my computer then I found out that my USB ports on my computer where bad. Just something to check
Ok so let's just start with the 3.2 version.
It will change com ports with your computer as you move usb to USB. Does it do that at least?
Ok so when you pick a USB port on the computer using the 3.2 version the comport pops up. If so select that comport.
At that point does the read button light up.
And I'm sure your car is running cause it needs to be.
If it makes contact then don't update the box.
If not I know what to do.
I'm going to have to go back to the 3.2 software.
I'll have to do it tomorrow though. It's 1030 here and my car is pretty loud.
Thanks for the help, I'll let you know what happens
Bringing this thread from the dead. I have installed the N2MB WOT box today and having some troubles with it. Rev limiter and No Lift Shift feature work fine, but the 2 step won't work at all. Any ideas? I've tried the troubleshooting procedures and it's working per the instructions. Is there something wrong with my settings?
