Looking to do a brake fluid swap and see several available. Just wondering what you guys use before I invest $200.00-300.00. I don't need a full featured commercial machine. Entry level is fine as long as I can bleed the ABS Module. Thanks
Usually, it's a Dealer Only Tool. The software is unique to an ABS Unit and most often proprietary. Aftermarket OBD2 Dongles and associated device don't have that software. If you knew the ABS Manufacturer, you could approach them but am skeptical they would let you have their proprietary software, which would need some hardware.Looking to do a brake fluid swap and see several available. Just wondering what you guys use before I invest $200.00-300.00. I don't need a full featured commercial machine. Entry level is fine as long as I can bleed the ABS Module. Thanks
Several user comments say it does run the ABS Pump and hopefully that includes cycling all ABS Solenoids in the ABS Unit. If it does both for your car, then it should be fine.Guys, thoughts please, this unit claims to do it for a bunch of auto manufacturers. Also a few YT vids of guys using this exact make and model:
Autel Maxicheck Pro for ABS Brake Auto Bleeding OBD2 Scan Tool with Airbag, EPB, SAS, BMS, Oil Reset Services for Specific VehiclesDefault Title
Autel Maxicheck Pro is a specialty tool for technicians & garages. Focus on one or more service functions, like EPB, Oil Service, ABS, SRS, BMS, DPF etc. Sale online store at wholesale price.US/EU warehouse.www.obdprice.com
Let us know what you find...There’s also a few Innova models that claim to do it as well. More research. Thanks guys.
You should call Innova and talk to a tech and ask specific questions...Looks like the Innova Car Scan 5510 will fit the bill, plus they are located in Ca. The other one I mentioned above is in China. Good luck with tech support there! Ive got to check more reviews however.
Years ago -- sometime after 1996 when OBD2 appeared -- I bought an Actron scan tool. It didn't support access to other control modules or ABS pump cycling or anything like that. But it did offer the ability to trigger the built in tests some engine controllers supported tests to check O2 function.Looking to do a brake fluid swap and see several available. Just wondering what you guys use before I invest $200.00-300.00. I don't need a full featured commercial machine. Entry level is fine as long as I can bleed the ABS Module. Thanks
Vacuum Bleeding is not recommended for ABS Systems..Thanks @Rockster I’ve got the vacuum bleeder from Harbor Freight and the fluid as well. Just wondering if half assing it by not bleeding the abs module us worth the 250.00 I’m going to dump on another seldom used tool. Love to hear feedback from someone who has used it, or another, before.
Yep, once I discovered the pressure bleeding, I was hooked. I actually enjoy bleeding them now.Vacuum Bleeding is not recommended for ABS Systems..
