1 - 10 of 10 Posts
Hey everyone. I'm doing a Hellcat front front bumper swap (non wide body) on a 2015 Challenger. I have all oem pieces including what I believe is the correct non-foglight wiring harness. It's come's with the zip tie push pins already installed in the "correct" positions, but I don't see where they would snap in on the inner portion of the Hellcat bumpers/reinforcement/grilles. It's almost like it made for a non fog-light base challenger. There are only two part numbers for the 2017 Challenger. One part number with fog lights and one without. Strangely, neither part numbers show that they are applicable to the Hellcat, which you would think the non-fog light would almost have to be.
-68259673AB Non Fog-light (I bought this)
Wiring Front End Lighting
[MLA], [X8W]
-68259674AB With Fog lights
[MLA], [X8W], [LNJ]
I can take a pic of backside of my bumper if that helps. I've attached a pic of the harness in reference. Thanks.
· HOTY Winner
It is mounted to the front bumper cover. The connecter is on the passenger side in the fenderwell. You will need to remove bumper cover to get full access.
· HOTY Winner
Go to 5:55 in video to see connector.
Discussion Starter · #6 ·
The Hellcat grilles and inner absorber is different than the non-Hellcat cars. That appears to be a scat pack or srt8 in video. The Hellcat doesn't have any places for the clips to push in like the others. I think it may get tucked in behind the foam absorber from looking at it last night again. That's what I went with. Thanks for the input, tho.
‘16 A8 Shaker
Yours had a foam 5mph piece? Weird. My ‘16 had a stupid plastic one. Guaranteed to cause more damage God forbid.
I don’t see how you could tuck the wires behind it as it’s clipped to the bumper?
2015’s don’t have a separate wire harness for the side markers like the newer ones do. Should all be connected to the headlamp to dash harness. Just reach your hands down on left side by abs and right side under air box and plug them in, the wires for the side markers should be short. Just leave it
I think you’re just confusing yourself with that wire harness, did it come with the hellcat front bumper you got? If so, it’s probably off a 2017+ car and isn’t even needed. Your 2015 challenger has the connections for the side markers built into the headlamp to dash harness
1 - 10 of 10 Posts
