check engine light on. Dealer can not seam to fix it. Keeps talking about Dodge Star system what is Star System. 2015 Charger Cat. Thank you in advance with your help.
You should have asked the dealer/service department what the Star System is. I googled this in various ways and nothing came up.check engine light on. Dealer can not seam to fix it. Keeps talking about Dodge Star system what is Star System. 2015 Charger Cat. Thank you in advance with your help.
What code(s) are displayed on the center display, Catalytic Converter(s)?? What code(s) is the dealer getting?? More info might help...check engine light on. Dealer can not seam to fix it. Keeps talking about Dodge Star system what is Star System. 2015 Charger Cat. Thank you in advance with your help.
p0172 code dodge charger - Bingcodes are P0172 P0175 Upper Pulley .....AFTER Market cold air filter UNLOCKED COMPUTER . These mods were done 4 years ago by HHP. Codes started to appear in May 2021. Low mileage 5,500
Codes P0172 P0175You should have asked the dealer/service department what the Star System is. I googled this in various ways and nothing came up.
What are the error codes? Is the engine manifesting any signs of any issues? Is the car/engine stock? Miles?
Both banks running rich.Codes P0172 P0175
Thank you for your help , much appreciated.Both banks running rich.
The suggestion to contact HHP is a good one. HHP apparently supplied some "tune" to accommodate the upper pulley change and possibly the intake modification.
That both banks are running rich suggests a common failure. First thought is the fuel pressure is off. If too high this can result in too much fuel being injected. But my 2nd hand experience is fuel pressure regulators do not fail in a way to provide too much fuel pressure but too little.
Oh, be sure the aftermarket cold air intake system is ok. The intake system before the intake manifold plays a critical role in helping to ensure good air flow, laminar air flow, into the intake system which includes air flowing past/through the MAF. Now IIRC these engines do not use a MAF but some other sensor. Still it is important the air flow be as good as it was with the factory setup to ensure the air flow doesn't affect the ability of the sensor/ECM to determine the correct amount of air being consumed by the engine and to add the proper amount of fuel.
Thank you for all your help. This sheds light with STAR.Star stands for Service Technical Assistance Resource center. It’s for mopar techs to talk to FCA engineers that may have additional resources/info on how to go about fixing a specific problem with a vehicle. There are different levels of support as well. If they cannot help the tech come up with a fix for the vehicle remotely, they will probably send someone to the dealer to remedy the situation.
Thank You Blickie
Did you ever find out what was the problem behind those codes? Because I’m having the same issuecodes are P0172 P0175 Upper Pulley .....AFTER Market cold air filter UNLOCKED COMPUTER . These mods were done 4 years ago by HHP. Codes started to appear in May 2021. Low mileage 5,500
