Had 1970 Road Runner 440 4 speed about 15 years ago.Congrats. First Mopar?
Going to look into that car has 22k on itLooks like the IC tank has the original purple coolant, but the engine overflow tank has had its coolant changed to orange coolant for some reason....hopefully it didn't overheat.
The larger coolant tank has a bright light on it so it looks lighter.Looks like the IC tank has the original purple coolant, but the engine overflow tank has had its coolant changed to orange coolant for some reason....hopefully it didn't overheat.
Could be.... The OP will see it again in person. Doesn't mean anything horrible necessarily. Could've had a hose replaced. Most of the non-OEM coolant out there that meets Mopar spec is orange. But I'm technically color blind too so... But the car looks nice!The larger coolant tank has a bright light on it so it looks lighter.
Bet if you put a piece of cardboard over the tank, the coolant will look the same color as the IC tank.
Edit: Nice ride!
Thanks I'm in TwinsburgWelcome to your new Hellcat. Where in NE Ohio are you? I'm in Parma.
